Well, as the title says, I'm trying to convert a video from PAL to NTSC. I'm using the tutorial you can find here. After encoding with TMPGEnc, the .m2v file is just black. I've used several players to try and get something, but all have the same results. The interesting thing is that one of my players tells me that the TV system is unspecified, which I believe is my problem. Does anyone see any flaw in the tutorial or have any suggestions for me to try and get this right?
Yes, it is. I noticed that when I started encoding, but went through with it anyway just to double check.
what is your source video? avi? mpg? use gspot to identify.
try change the directshow priority in tmpgenc, www.videohelp.com/tmpgenc#problems
PAL to NTSC and black level
By Mike99 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Aug 2010, 04:05 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
