Hey guys!! I have a problem w/ quicktime 7 (free downloadable version from APPLE) and I got a movie that is in AVI format.
But,, when I click the movie that is in AVI format the Quicktime7 opens and a window pops up saying:
Some necessary Quicktime software is missing. It may be avaliable on the Quicktime website.
If you have dialup connection to the internet, make sure it is actve, then click the continue button to check for the software.
Then if I click the contunue button it takes me here:
http://www.apple.com/quicktime/resources/components.html
What am I missing guys? I can tell you that the movie opens up in quicktime, and then when I hit PLAY it only has sound, and it sounds like it is a skipping CD or something. As for Picture. I have no picture what so ever.![]()
So if anyone know or has a guess on what I need, please post? Thanks a bunch all!
Results 1 to 9 of 9
*New Mac user*, been PC user 4 life
Im no expert, but AVI files need different codec to decode them and there are lots of them for this file type. in the distant past when I had this problem sometimes Dixiv would work but after you converted them
don't remember how I did this, but if you go to the divix site, maybe you will find something
also there was a freee avi to qt convter way back that sometimes worked best look vor that in versiontracker
good luck but lots of avi with different codexcx won't work with qt
hope this is a start for you
rotutMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Thanks let me try some thngss
*New Mac user*, been PC user 4 life -
-laugh while you can monkey boy! - Dr. Lizardo
OK,, I did Open apple and I , got the info tab up. Does not tell me nothing just that is is a AVI. thats about it.
But let me just say this. I downloaded VLC and installed it to my desktop. Now the movie works w/ VLC. Thanks a bunch man!! Made my day. Now I like to know what I can do to convert this AVI to work on my home dvd players and not just on my MAC. Any suggestions? Easy software perferd.
Thanks*New Mac user*, been PC user 4 life -
You have to give us EVERYTHING in the Command I
info window to be able to help you.
Just saying "all it said was AVI"
means that we can't point you in the direction of
getting you software to transcode it into a usuable QT based format.
Go back to the avi, get info and following the attached picture,
give us everything shaded in RED:
Once you post that info back,
we'll be able to point you to CODECS you will need
to get the file transcoded so you can put it on a DVD."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Terr:
a little OT but how do you post the pics as you did with the get info in this or other forum(s)(i)
thanks rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
rotus
you have to use the "post Reply" button,
not the "quick reply" button.
in your posting use [img]https://www.videohelp.com/forum/images/guides/p1305787/ and then
use [/img]
or .gif file file.
Then, below where you post,
there is an uplink
button, upload your image using that.
once the image is uploaded here,
it will automatically display
where thestring is.
for more info, go here:
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
Best import to Quicktime...
By bsuska in forum Video ConversionReplies: 26Last Post: 23rd Sep 2009, 15:03 -
Quicktime
By skipowder1 in forum ffmpegX general discussionReplies: 1Last Post: 19th Jul 2009, 17:12 -
quicktime
By devdev in forum Video ConversionReplies: 2Last Post: 28th May 2009, 03:40 -
Quicktime 7.4
By matthewjohn23 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Apr 2008, 15:42
