I have downloaded and extracted a DVD ISO which I wish to convert to VCD. I'm attempting to convert the VOB files to MPG or AVI so i can then use TMPGEnc to create a VCD.
I'm having major problems ripping the VOB files. FlaskMPEG, DVD2AVI,DVDDecrypter and Eazy VCD are all crashing before they start.
What's going on? Unfortunately I can't copy the standard error report, but hopefully the following will help.
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="FlasKMPEG.exe" FILTER="GRABMI_FILTER_PRIVACY">
<MATCHING_FILE NAME="FlasKMPEG.exe" SIZE="324096" CHECKSUM="0x19B24DEE" BIN_FILE_VERSION="0.7.8.39" BIN_PRODUCT_VERSION="0.7.8.39" PRODUCT_VERSION="0, 7, 8, 39" FILE_DESCRIPTION=" FlasKMPEG program file" COMPANY_NAME="FlasK Inc." PRODUCT_NAME="FlasK CO FlasKMPEG" FILE_VERSION="0, 7, 8, 39" ORIGINAL_FILENAME="FlasKMPEG.exe" INTERNAL_NAME="FlasKMPEG.exe" LEGAL_COPYRIGHT="Alberto Vigatá Pascual - Copyright © 2000" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.7.8.39" UPTO_BIN_PRODUCT_VERSION="0.7.8.39" LINK_DATE="10/28/2002 10:46:58" UPTO_LINK_DATE="10/28/2002 10:46:58" VER_LANGUAGE="Spanish (International Sort) [0xc0a]" />
</EXE>
<EXE NAME="aviout.cm.flask" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="aviout.cm.flask" SIZE="92160" CHECKSUM="0x6FC5C53C" BIN_FILE_VERSION="2.0.0.4" BIN_PRODUCT_VERSION="2.0.0.4" PRODUCT_VERSION="2, 0, 0, 4" FILE_DESCRIPTION="OpenDMLAVIOutput DLL" COMPANY_NAME="" PRODUCT_NAME="OpenDMLAVIOutput Dynamic Link Library" FILE_VERSION="2, 0, 0, 4" ORIGINAL_FILENAME="OpenDMLAVIOutput.DLL" INTERNAL_NAME="OpenDMLAVIOutput" LEGAL_COPYRIGHT="Copyright (C) 2000" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="2.0.0.4" UPTO_BIN_PRODUCT_VERSION="2.0.0.4" LINK_DATE="10/28/2002 10:44:58" UPTO_LINK_DATE="10/28/2002 10:44:58" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
<EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY">
<MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x4CE79457" BIN_FILE_VERSION="5.1.2600.2180" BIN_PRODUCT_VERSION="5.1.2600.2180" PRODUCT_VERSION="5.1.2600.2180" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFF848" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.2180" UPTO_BIN_PRODUCT_VERSION="5.1.2600.2180" LINK_DATE="08/04/2004 07:56:36" UPTO_LINK_DATE="08/04/2004 07:56:36" VER_LANGUAGE="English (United States) [0x409]" />
</EXE>
</DATABASE>
Have you burned the iso to dvd or are you mounting the image?
Google is your Friend -
The reason I asked is because you stated that you had a dvd iso. An iso file is an image of a disc. There are many programs ( such as Alcohol 120% ), that can mount the image ( makes the image appear as a DVD to the pc). Then you can just play it.
If you've already gotten the vob files, take a look in the "HOW TO" CONVERT section on how to convert the vob files to avi or whatever.Google is your Friend
Xvid4psp crashes
By skorpinok in forum Video ConversionReplies: 1Last Post: 9th Jul 2011, 13:59 -
AVStoDVD Crashes
By Bonie81 in forum Newbie / General discussionsReplies: 3Last Post: 12th Oct 2010, 07:53 -
crashes
By idolgolf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2010, 05:43 -
What to do when your PC crashes?
By aelfheah in forum ComputerReplies: 6Last Post: 29th Oct 2008, 11:27 -
2.5 crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 20th Jul 2007, 03:49
