I am converting a MOV file to dvd format so i can burn to dvd. The destination folder has many files. it has a .m2v, .mpa, .mpg, so how do i burn this to DVD? do i select all files to burn to dvd or is there a main file that i select and it will automatically link all files?
what do you convert with?
the m2v is the video
the mpa is the audio
the mpg is the audio and video together
so you can just add the mpg in your dvd authoring tool. -
it converted it to mpeg but my dvd player is picky so i need something that converts to the VOB format. I am trying ProShow Gold which will do that but it seems to lock up often. wonder if there are any other programs.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Unsuccessful conversion from .mov to DVD
By euskir in forum ffmpegX general discussionReplies: 4Last Post: 7th Apr 2010, 16:12 -
Mac Conversion from DVD to .Mov? Any suggestions?
By Jeff_NJ in forum MacReplies: 8Last Post: 1st Oct 2008, 15:28 -
.mov to dvd conversion
By tomm2000 in forum Video ConversionReplies: 1Last Post: 7th Sep 2007, 16:23 -
.mov to DV conversion
By aaron_rip in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jul 2007, 16:55
