When I wanted to import a movie in Adobe Encore DVD I got an error:
Could not import file xxx.mpg - the file type is not supported
what can I do?
Results 1 to 18 of 18
Make sure the file is a DVD-Compliant resolution and bitrate.
Details of the source file:
MPEG-1 VCD
29.970 FPS
352 X 240
Bitrate: 1150 kbps
Audio: MPEG-1 layer II
44100HZ
224Kb/s -
Adobe Encore sucks for this very reason.
It does not support the full DVD spec.
However, your audio is wrong for DVD.
And the MPEG-1 may or may not have proper sequence headers.Want my help? Ask here! (not via PM!)
i thought encore was a sweet software for burning?
i use dvd archetech.
have you tried that? or only using Encore? -
I converted the sound to 48000HZ and nothing changed.
I used just Adobe Encore. -
Does Encore import muxed video? IIFC, it is the next gen of DVDMaestro, which only imported Elementry Streams.
Try demuxing video and audio into ES.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I demuxed the mpg file. I imported the m1v file into Adobe Encore and nothing changed.
If I will change the resolution of the video to 720x480 (standart of dvd) I will be able to import the movie in Adobe Encore?
Here this may help.
It is from the Encore Help file.
Supported video files
Video must conform to one of the following frame rates and frame sizes, depending on the TV standard you plan to use for the project:
Standard
NTSC
PAL
Frame rate (frames per second)
29.97
23.976*
23.978*
24*
25
Frame size (pixels)
720 x 480
720 x 486
704 x 480
720 x 576
704 x 576
* Transcoded on import to convert to 29.97 fps.
You can import the following video file types: AVI, MPEG-2 (including MPG, MPV, and M2V), and MOV (transcoded on import).
_ -
But no mention of MPEG-1 video files. And, a MPEG-1 video at 352x240 is a valid DVD resolution
If I will convert the file to MPEG2 720x480 with TMPGEnc (templete dvd [ntsc]) I will be able to impot the file in Adobe Encore?
I had the same problem with Adobe Encore 1.0. it has some limitations when trying to import an MPEG1. Version 1.5 may be better. If you encode the file to MPEG2 720 x 480 you should be able to import it but you will have to try it to be sure.
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 06:30 -
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 05:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 16:05 -
CDCheck - same error repeated, seems to start in Adobe Encore
By moxiecat in forum Authoring (DVD)Replies: 1Last Post: 26th Dec 2008, 16:25 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 19:24
