I'll be making a series of clips available in a number of formats. VCD and DVD compliant MPEG-files are already being processed as I type, however I'd also like to make a "small download" file.
What do you recommend for the codec if I wanted to make, say, 256kbps / 64kbps version? MPEG4 / XviD or MPEG1? 160x120, 240x180?
This is intended for (1) people on dialup, and (2) those who want quick previews. I'm aware the experience isn't super, that's why VCD and DVD will also be available. However 256/64kbps is pretty much what I'm going with for the small version, and I'm looking for the best solution for producing just that. The file lengths will vary anywhere from five to fifty minutes, not that it should make any difference with this.
Sounds OK to me!Originally Posted by RagaThere are 10 kinds of people in this world. Those that understand binary...
if you make it xvid or mpeg4 ... people most likely will have to download a codec and install it - which is something most people will not do ..
Right. I remember having issues with people not being able to install codecs before. So I should then probably just go with MPEG1...
However what's with Archive.Org and their MPEG4 that only works with Quicktime? (See this post.) Any clues as to what's behind the rationale? -
Thats a good point. WMV would be a good alternative.Originally Posted by BJ_MThere are 10 kinds of people in this world. Those that understand binary...
Most cost effective way to back up 20GB files?
By chris2200 in forum Newbie / General discussionsReplies: 17Last Post: 24th May 2011, 14:34 -
BD Rebuilder output files too small
By mpullar in forum Blu-ray RippingReplies: 9Last Post: 18th Mar 2010, 17:58 -
Raw MTS files so good, and so small
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Aug 2009, 00:20 -
mkv2vob files get small!
By smekast in forum Video ConversionReplies: 0Last Post: 25th Jul 2008, 04:41 -
my avi files appear too small on tv...
By vinayak1986 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 23rd Dec 2007, 18:48
