hey I downloaded this video... and it came as a .iso file
I've burned files that come as .bin/.cue but never an .iso
I tried "burn image" with nero.. but the file is too big for one disk I guess...
anyone wanna fill me in on what to do pretty please with sugar on top
thanks
You can use DVDDecrypter to burn an ISO to DVD. You can also use DVDShrink to open the ISO and if needed, reduce the size.
So what kind of video do you download that is bigger then 4.3 GB? If it is just a video(no menu) the easiest thing to do to split it is to use the reauthor in DVD shrink and use section selector. Otherwise, just shrink it.
This plan is so bad, it must be one of ours.
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Viewing ISO before burning
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 11th Sep 2008, 17:34 -
ISO to DVD burning?
By sufcdan in forum MacReplies: 8Last Post: 22nd Feb 2008, 14:42 -
Iso Burning problem.
By whendreamsweep in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2007, 11:24 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
