Hi, i have an Aiwa XD-DW5 DVD Player, and i was wondering something about the region hacks posted on this site.
https://www.videohelp.com/dvdhacks.php?select=Aiwa+XD-DW5
1. Are these hacks tested? will they ruin my player?
2. it says "Region code or Macrovision hack" what does it mean by macrovision hack? like if i enter the region code, it removes macrovision?
3. if i apply this code, will it allow my dvd player to play dvd+/-r's?
thanks
I don't have your player, but I should be able to answer your questions.
1) If the hack involves pushing some buttons on a remote control, there should be no risk of damage to your player. If the hack involves installing firmware, yes, there is a risk of damage if you do something wrong and don't follow the instructions.
2) Macrovision hack means that the hack removes Macrovision from the video output. Region code means the hack removes region code checking. Some players only have hacks for one of these, some have hacks for both. Many players have hacks for neither.
3) No hack will change the ability of your player to play DVD+/-R discs. That depends on the laser inside and can't be changed by a hack.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 17:53 -
Need Help: Region Hack for DVD Player Toshiba SD-6100KU Thanks
By Panchogun in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Nov 2008, 12:40 -
Microvision In Car Dvd Player - need region hack please!
By vanishingbluepoint in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2008, 19:38 -
Need region free hack for DVD/VCR player: LG V271N
By Tindaloo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Oct 2007, 12:05
