    May 2005
    Israel
    Is it possible? If the answer is yes then how?
    A Yellow Submarine
    Yes. Hook the video and audio out of your DVD player to the input of your Beta recorder. Just hit play on your DVD player and record on your Beta recorder and you are good to go.
    You may have some problems with macrovision errors being recorded. In that case, you will have to find a hack for your DVD player on the left or buy something to defeat the macrovision and install that device between your DVD player and Beta recorder. Topic here about the possible devices you can use.
    Sep 2003
    Northern California
    Macrovision might not pose a problem.
    If I recall correctly...Beta was immune to macrovision because it normally rebuilt the sync signals when it recorded.
    May 2005
    Israel
    thx. Is it possible to record subtitles as well?
    canada
    Some beta such as sanyo couldnt bypass macrovision,as to subtitles they have to be shown and then they will be permanently recorded to tape.
