i just installed hollywood fx pro on my computer and it's not showing up in adobe premiere pro 1.5. is there something i need to do... move some drivers, etc... to get it to work? the program works by itself, but isn't showing up in adobe as a plug-in or nothing. thanks for your time and any help.
- Jason
Did you install the one specifically for premiere? There is one for Studio one for Liquid Edition and one for Premiere.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
there wasn't an option for two different kinds of hollywood fx programs. there was only one download on the website. anyone else have any suggestions. thanks.
what files do i need to copy to adobe's plug-in folder to get this to work? thanks.
I thought that I read yesterday in the Premiere usersgroup that for some reason you can't use Hollywood FX ver. 5.2 with Premiere 1.5. If you are using 5.2 or later, that may be your problem. Please check out the Premiere users group over at Adobe to confirm my story.
Mark
Imported pictures Premiere are showing black!!
By trunkims in forum EditingReplies: 14Last Post: 27th Sep 2013, 01:40 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27
