Dear all...
I am considering a power center/conditioner for my video/audio sets. Does it really matter to have one, in terms of quality of the pictures. Can one really tell the difference?
Also, what does "joules" mean? I understand it's reflecting how much protection there is from power surge, right? How high is sufficient (1500)?
Thanks all in advacne.
Yes, having power conditioner is good idea, but no, Monster is overpriced and a rip. Any UPS battery backup surge box with AVR (auto voltage regulation) will be fine.
Yes the Monster Power Center is way overpriced, and does not include UPS battery backup. UPS battery backup will prevent system problems that occur if your computer powers down without exiting windows properly. This is more important in the summer when entire powerplants are added to the system during hot days which create power spikes, and brownouts when the power is not high enough to prevent your system from rebooting.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
Don't have a Monster Power Center, but I do have 2 Panamax surge protectors which have line filtering. They lessen the noise coming thru the AC line making video and audio cleaner - enough of an improvement that I wouldn't want to be without them. About the same amount of improvement you'd see/hear upgrading to premium-quality cables.
They do make cheaper ones than those listed here, but this will give you an idea:
http://www.panamax.com/products.cfm?group=1&sec=group
joule rating = how much cumulative surges it can absorb before the unit is fried (higher the better, but also more expensive). -
If anything, a power conditioner will extend the life of your equipment. An $80 UPS will give you some good protection. A 750 ought to cover it, probably more than you need.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
External power supply question (media center related)
By dbanimal in forum Media Center PC / MediaCentersReplies: 5Last Post: 16th Sep 2011, 00:49 -
Power Conditioner enhancing VHS performance
By OldMedia in forum RestorationReplies: 8Last Post: 11th Apr 2010, 03:39 -
NERO 9: OMG what a monster!
By jsmithepa in forum ComputerReplies: 16Last Post: 21st Apr 2009, 20:09 -
Power/Electricity setup - UPS, Surge protector, line conditioner...
By Anonymous4 in forum ComputerReplies: 18Last Post: 22nd Sep 2008, 17:43
