ffx version 0.0.9s
OS: tiger or 10.3.9
platform: 800Mhz G4 imac
Quicktime 7
toast titanium (without jam)
problem: AVI (XVID) play fine in vlc player, mplayer, and ffmpegX. ffmpeg can convert it to H.262 high def just fine.
But if I convert it to VCD or DVD, the video is solid black without sound. FFmegX runs for a long time with no more than the usual warnings in the log and finishes normally authoring the bin/cue or video_TS folder. I am using the default settings for the conversion though I have tried a few others as well.
As I said it does convert to H262 high def and it plays. I can also convert it to MPEG4 (mplayer) and it plays.
What's strange is the same thing happens if I try to convert the file using toast titanium.
How is it possible that the large (400Mb) cue or video_TS can be produced and be all black yet all the players can play the source files video and audio.
I've done this many times now at the outcome is reproducible.
I do NOT have XVID or 3IVX installed in quicktime. (nor do I want to particularly)
Thanks! I will give this a try. too bad the preview function does not use the same decode as the rest of the program--makes it confusing. What are the relative merits of decoding with quicktime versus mplayer. Should I always default to quicktime when it works and only use mplayer when it does not. Also what happens if I dont select either decoder--is there yet another one?
Black (blank) screen after converting MKV to BD with TSMuxer & ImgBurn
By Jijital in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Oct 2011, 08:24 -
Converting to Xvid with large screen size
By hasanali00 in forum ffmpegX general discussionReplies: 3Last Post: 16th Feb 2010, 19:05 -
black screen on ps3 after converting video
By unknownguy in forum Video ConversionReplies: 1Last Post: 22nd Jan 2009, 07:26 -
Blue Screen of Death while converting .avi to DVD
By robwbright in forum ComputerReplies: 7Last Post: 5th Oct 2007, 21:53 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
