I'm 47 years old , a retired Navy vet that worked on the flight deck as a member of the crash n salvage team and my avatar is my grandkid. Trust me when I say that you have a long way to go to get under my skin. You do make me chuckle though, and for that I do appreciate you.Originally Posted by p_l
Let's Rock.
Results 31 to 38 of 38
OK, agreed. The End.
Let it be noted that I did try to help the original poster.
Hell StilTman
Windows Registry Editor Version 5.00
Can you help me how to change Dword[HKEY_USERS\S-1-5-21-1409082233-1060284298-1417001333-500\Software\CORPUS\EPSON Print CD\Printings]
"Bore"=dword:0000000f
any software to edit that
I got to this point, but no way I can change this Bore = dword
Please help
I got the same problem with epson can not print to the hub, after print it still has the white circle left.
I would like to set the label print over 20, but set 20 from epson that is maximum I would like to set to 15
thank for you help -
-----------copy---------------Originally Posted by born2blove
------------copy---------------
Paste it into a text document
save it
change the extension from txt to reg
right click and select merge
open epson software
15mm center "bore" hole
BTW, Y'all are real funny
Seems to be off topic now....
I modified a Lexmark Z11 for DVD printing. Hail to The Village Idiot. No idiot at all as it turns out....
Well... I have no DVD printing software at all. I do all with MS Powerpoint. ?????? Yes. I have a pattern saved and use a vertical plus horizontal line that represents the disc to center the picture. Scan the DVD as an image. Crop. Insert it and center it. Print and off we go. No limitations and perfect results. Just needs a few prints on paper to align the pattern before you go ahead with discs. Don't complain - be creative!
Vid -
Thank you for you help Stilman
I copy the and paste it in to notepad han save it at text file name = inner15.txt
than I rename it to inner15.reg
right click and merge
small windows popup and asking me for permit add it in to registry
I click Ok than I got error " The specifield file is not a registry script. You can only import binary registry file from the registry editor"
I use xp-sp2
TMPGEnc DVD Author is driving me nuts!
By dafoe in forum Authoring (DVD)Replies: 9Last Post: 25th Jul 2010, 00:04 -
Bugs Bunny is driving me nuts.
By G)-(OST in forum Off topicReplies: 15Last Post: 24th Jun 2009, 22:52 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 09:26 -
v2.5.3600 runs very slow and driving me nuts...!!!!
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 6th Oct 2008, 10:00
