How can I ensure that my authored dvd will fit on a dvd-5 (4.37GB) or 4480MB when TDA measures discs as 4.7 and 8.5 GB respectively? My pre-authored files are fine as far as size, but when I author, bang always 4.68 GB, too big to actually fit.....used the calc program to determine bitrate and size is fine, but TDA authors files too large! HELP
Hi mcpogue,
Are you using menus and chapters etc.? Do they have still and / or motion backgrounds? All of this takes up additional room on the disc and needs to be allowed for.
The difference between 4.37Gb and your 4.68Gb sounds about right for menus, chapters etc.
If you're encoding (you don't say where the MPEGs come from), then encode with a bitrate with the aim of getting an end filesize (video + audio) of 4Gb.
If you're not doing menus etc., then I'm not sure what's going on...
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
No menus, no nothing at all? I'm not sure if, even in this case, there is an overhead - either just with TDA, or all DVD authoring apps.Originally Posted by mcpogue
Running time of footage?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I think it might be something in TDA.
I did a movie that should have fit, TDA said it was just a touch over the limit for a dvd-5, i figured i would shrink it a hair after with dvdshrink, when i was done i checked it in dvdshrink and it said it was 100%, so i opened it in nero and it was actually under the dvd-5 limit.
So it must be TDA reporting some things as larger than they are.
I never had this heppen before, and i use TDA alot since it first came out, so i'm not sure why it happened.
I would run it and then see if it will fit with nero or W/E burning program you use. -
TDA always complains of "over the limit" stuff with me. i had an m2v & an ac3 that totaled 4.32 gb. i authored it with TDA, with no menu, and TDA still complained.. the output files were 4.32gb as well.
one thing that might be screwing this guy over is motion menu's.. TDA hardly uses any space for regular picture menu's.. but 300+ mb sounds like motion menu's.
in the "create menu" section click the "menu settings display" button, it will bring up the "menu settings display" window, click on the "motion menu" tab & uncheck the "use motion menu" box & click OK,
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
