  1. I want to convert anologue video tape to mpeg, eventually on to vcd what codec's do I need.
    Regards: Patsym1
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    None! All you'll need to do is capture it, convert it to mpeg using TMPGEnc and burn using Nero!
    I only dream in black & white...
    MSN: paschendale@gmail.com
  3. if your captureing try this codec cal Huffyuv:
    get it here:
    http://www.math.berkeley.edu/%7Ebenrg/huffyuv.html
  4. You guys make this sound soooo easy!!! and it isn't!! at least not for me.
  5. Thanks guys for your prompt replies.
    Regards: Patsym1
