Im trying to make a new app that will mux mpeg2 audio and video to a (X)SVCD compilant mpeg2 file. The problem is that I only have a iMac DV. That means I will not be able to encode mpeg2 files from programs as iDVD and DVD Studio Pro (they need a G4 to run).
If someone owns these programs or one of them and wants to help me out, please contact me.
* I just want you to encode a 30sec clip for me. I have the clip ready and just want some help with the encoding so I can test them on my new app.
Best Regards!
Jesper Nilsson
Developer of vcdtoolsX and MPEG Info.
http://www.sbpr.a.se/systemjammers/
RNC here, I may be able to help you out with this, but I only have DVD Studio Pro.
Yo RNC / Ross!
Do you have a clip that you could encode and send to me? I would also want the source (,mov) file. This would be so great.
Also what settings in mPack do you recomend, if any?
/jesnil -
jesnil: I just uploaded my guides to SVCD using both os9 and os10, there is are links to download my configuration scripts for m.pack and Cleaner also.
http://homepage.mac.com/rnc/
I understand the source .mov, but how do you want the the clip encoded?
Audio Encoding Help needed for VirualDub
By Qasim in forum AudioReplies: 8Last Post: 30th Apr 2010, 08:02 -
Guide needed for Video Capture and Encoding
By jsmithson in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2009, 05:05 -
Encoding tool needed
By 557953 in forum Video ConversionReplies: 8Last Post: 8th Sep 2008, 14:15 -
Advice needed with Raw DV encoding
By zack28 in forum Newbie / General discussionsReplies: 4Last Post: 1st Jun 2008, 17:59 -
GURU feedback needed: web server encoding and .flv size
By lucite in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 18:28
