I have a DVD-10 movie that has half of the movie on one side and the rest on the other side. How can I combine both sides and merge the menus? I can shrink it to fit but my question is how to merge the content of the two sides of the DVD-10 disc.
Thanks for the input but after I read the reviews of it on the link you showed, it seems like the comments are generally quite negative on the product. Do you have any other suggestions? Thanks.
That's because they prolly didn't invest the time to actually learn how to use it. I think it's a great program and it came through for me when I had to combine 3 DVDsOriginally Posted by SCDVD
Thanks, I'll give it a try. With input from two people who obviously know what they are talking about, it sounds like a good product.
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
Double Sided DVD to DVD-R
By craigwojo in forum DVD RippingReplies: 4Last Post: 22nd May 2007, 09:16 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
