I'm looking for a program that would make it easy to make a DVD with Divx files. I want to be able to just select the Divx files and create a DVD with menus without any converting before hand.
I've tried DivxToDVD but no Menus are allowed for it.
I've also got a 2nd question.
I've converted a video with D.I.K.O. into 2 seperate files, a .mp2 and a .mpv. I've tried using DVD-lab PRO to burn it with a menu but when I select the correct Menu option on the DVD, the audio plays but the video doesn't. How can I get it so the video and audio play?
Results 1 to 10 of 10
Load the .vob's from VSO DivxtoDVD into DVDLab Pro, author and burn.
Demux when prompted!Cheers, Jim
My DVDLab Guides -
I did this, but sometimes I get freezes and green specs every once and a while.
What does this mean, Koleman?Originally Posted by Koleman“He who makes a beast of himself gets rid of the pain of being a man.”
It means that you use your video card's video out feature hooked up to your DVD Recorder and play your DivX file on your PC while recording it to DVD.Originally Posted by thecrock
TBH I would never do it this way. It may be quick but it certainly isn't the best way IMO from a quality point of view.If in doubt, Google it. -
this is a good question... i am also wandering if there is any program or software out there that will take a .avi file and BURN to dvdr or cdr as video cd ... without converting to mpg first, thanks
----> adamf9898 ----> -
Impossible.i am also wandering if there is any program or software out there that will take a .avi file and BURN to dvdr or cdr as video cd ... without converting to mpg first
Then don't use VSO, find a better encoder. Start by reading through the guides for avi to dvd.I did this, but sometimes I get freezes and green specs every once and a while.Cheers, Jim
My DVDLab Guides -
The freezes aren't because of VSO DivXToDVD, they're from bad media.
I assume the green specs are pixels from a corrupted AVI or a compatibility problem with your DVD player. Again, bad media.
The original question was how to put DivX files onto a DVD without converting. To do that, you make a data DVD but you either need a DivX DVD Player to play them or you have to run an A/V out from your VIVO card on your PC out to your TV or just what them on your PC.
Obviously, you won't be able to create a menu but a Data DVD has it's own menu. If you have a bunch of small AVIs then you can separate them into different folders for easier access before you burn.
Also, the bad media that won't play DVD movies on your DVD player should play just fine as a data DVD.
Please help me,Dvd to mpeg,The most easiest way!!
By adrianneow in forum Video ConversionReplies: 2Last Post: 7th Jun 2011, 09:09 -
The easiest way to convert dvd to mp4
By karib in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 17:01 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 16:16 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35
