Results 1 to 9 of 9
  1. Hi.
    My mother just bought her first pc at the ripe old age 0f 71 and
    she's just waiting to be connected to the super highway. The pc
    was only a ton and it's a tiny with a 14gb hd and 64 ram.
    She only wants it for the internet so i suppose it's a start, when
    she said tiny i was like no no but she went ahead and bought it
    from a close friend.
    Now i want to put XP on it but i'm not sure if its a easy to do on a tiny
    as in my own pc which was bought and made to order from Infiniti PCs.
    I tried to format a friends dell pc and had to use the discs that came
    with the pc not the method i use on my own.
    Questions..
    Can a tiny pc be loaded with windows xp straight from the disc, can it
    be formated by just inserting the disc and going the format and load
    straight off the disc.
    Parts....to upgrade the ram do i need to by tiny parts, the pc is all oringinal tiny nothing added since new or do most pc shops sell parts
    to suit a tiny.
    My mother lives 30 miles from me so i want a good idea what i need to
    do before i get there.
    I do a know a bit about pcs myself but have never owned a tiny.
    thanks
    We're Bought and Sold
    For English Gold.
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Is tiny a brand, or merely some street slang for an old PC?
    I think that the minimum requirement for XP is 233Mhz and 64M ram (I would go with at least 128 to be safe). If you have that, then it will install, no problem. To upgrade the ram, simply find out what kind of memory it uses and get more (I had one with only one slot, so I had to replace rather than add).
  3. It's a (unfortunately popular) UK brand.
    Go here http://support.tiny.com/support/
    type in the first 5 numbers of the serial, and it will give you some answer about all the hardware in that box.
    Cheers, Jim
    My DVDLab Guides
  4. I tired the number she gave me E10005 entered these first few digits and nothing, maybe this doesn't do old pcs, i'll need to visit and check it out more.
    For English Gold.
  5. Member Soopafresh's Avatar
    Jan 2004
    Upgrade her RAM to 256 MINIMUM for XP, or install Windows 95/98.
  6. They stopped making this ram i was told in 2 pc shops today, saw some like it on ebay but if i could have the exact details of this type i'd be happy, so i dont buy the wrong one.
    [/img]http://www.thenook.info/forum/index.php?act=Attach&type=post&id=15998
    For English Gold.
  7. We're Bought and Sold
    For English Gold.
  8. Any 184 pin SDRAM should work. Doesn't have to be PC66.
    Cheers, Jim
    My DVDLab Guides
  9. Banned
    Feb 2005
    USA
    Install Win98 on that machine.
    Mom won't notice the difference, trust me. My 81 year old mother-in-law has her internet PC, an ancient 333mhz with 128Mb ram, and a measely 4Gb HDD. She'd be lost if I were to even think about installing winXP on that device. Win98 is just fine for her surfing, email, and chatting habits as I'm sure your mother will do fine with this and her software/hardware conflicts will be minimized due to the OS not being bogged down with the limited resources these older PCs have.
    It took almost three months for her to understand mouse movement functionality, but she's now quite good at what she enjoys.
