A friend of mine bought a vhs on ebay from Europe which was made in the PAL format. My VCR is not PAL, but I have dvd recorder which has a built in "time base corrector?". If I run the VCR through the DVD recorder, will I be able to transfer it?
I know, I just could try it, but he needs to mail it to me and I want to save him the postage if I can.
thanks,
Matt
I suppose your TV is NTSC. You can buy a transcoder (hardware) to go from PAL to NTSC (VCR>Transcoder>NTSC TV), or you can try to capture the analog video as PAL to your PC, edit with Sony Vegas v. 6.0 and re-encode it to NTSC. In this case you'll go from 25 FPS (PAL) to 29.97 FPS (NTSC). Vegas is going to interpolate the frames, anyway; the result will be acceptable. I'm not sure if this convertion will also match the audio file. If Vegas does not work for the audio, I mean, if the audio is out of sync., you'll probably have to read a guide around here on how to use BeSweet to fix this.
You cant capture pal vhs with a ntsv vcr to computer,has to be a pal or multiconverter vcr,no way around it.
does this work
By sve in forum TestReplies: 7Last Post: 21st Apr 2012, 23:15 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Does not work.. What can i do?
By schr2004 in forum ffmpegX general discussionReplies: 0Last Post: 24th Jul 2010, 16:21 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35
