  1. Member wulf109's Avatar
    Jul 2002
    I installed this program but I keep seeing "smc not responding" in the Windows task box. The program seems to be running. It updates itself and reports port scan attacks. SMC is the programs exe file. Is it really working?
    The not responding comes up as soon as I go online.
  2. Member Soopafresh's Avatar
    Jan 2004
    You should scan your machine for viruses, preferably in Safe Mode. You might have Sasser. Just a hunch. I've been wrong many times before.
  3. I'm a Super Moderator johns0's Avatar
    canada
    I see that not responding in my mom's winme task manager so i believe its normal.Sasser is only for w2k/winxp.
  4. Member wulf109's Avatar
    Jul 2002
    I found the solution in the Sygate forum. You need to download version 5.5 which does not cause the error. The current version,5.6,has the bug. Sygate's official answer is to upgrade to the Pro version for $40.00
