I had a piece of software that would allow me to grab stills from a movie.. well, I have since lost it.
Does anyone know where I can get a program that will allow me to grab stills from a video? (AVI file).
Thanks,
Troy
https://www.videohelp.com/phpBB/viewtopic.php?topic=67426&forum=2
WinDVD and PowerDVD play .avi as well. -
Thanks.
I don't own either of those and was looking for a piece of freeware.
Troy -
The piece of freeware is tmpg. You should read the whole topic.
kinneera wrote:
Load the MPEG2 into DVD2AVI, save it as a project file. Then open it up in TMPGEnc, select the frame you want in the Source Range filter, and then use the "Output as file sequence" option from the File menu.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Select the one frame you want to capture as start and end frame. Back to the main window, select file> output to file> Sequence bmp, jpg, etc.
stills to video speeding up frames/sec or stop motion
By slnorth in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2010, 23:06 -
Urgent Help - Grabbing subtitle from MP4 or AVI file
By antinikhil in forum SubtitleReplies: 2Last Post: 8th Oct 2010, 16:14 -
My Movie Doesn't Have Any Frames?
By OllyPomm in forum Video ConversionReplies: 2Last Post: 18th Nov 2009, 18:54 -
panasonic lx3 stills camera movie mode
By charlietoosey in forum MacReplies: 0Last Post: 18th Dec 2008, 06:46 -
Importing stills into a Premiere Elements movie - how to optimise?
By netwiz in forum EditingReplies: 0Last Post: 2nd Jun 2007, 07:15
