Not sure which forum this should be in. Is the audio/video software program(s) used by Keaton in the movie White Noise real? If so anyone know what's it called and where to find out more info about it.
I would say there was nothing special about the software he was using.
Just some Audio/Video software,that couldnt do anything better then Adobe audition and Sony Vegas. (Only because he didnt do anything in the movie that these programs cant) -
If you watch the extras they even have the website and talk about the program and IC recoder's they use in real life for this.
http://www.aaevp.com/
http://www.aaevp.com/freq_asked_quest.html#audio%20files%20into%20my%20computerMost of the AA-EVP members use Cool Edit (Now Adobe Audition http://www.adobe.com/products//audition/main.html) but there are other applications that do a good job. The important features you will use is, reverse, amplify, copy, cut, paste, filter and noise reduction.
My son want's to play with this so i might have to break down and buy an IC recorder
Grain/noise removal software for macs
By Lexa in forum Capturing and VCRReplies: 0Last Post: 8th Jun 2011, 18:05 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 08:08 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
Coping VHSC tapes to DVD+r, lost content due to white noise
By PanMan in forum Capturing and VCRReplies: 2Last Post: 25th Sep 2008, 21:54 -
Green/white noise line under video with mpeg2 format
By VistaXP in forum Capturing and VCRReplies: 2Last Post: 27th May 2007, 19:29
