    Sep 2001
    Canada
    The DV-out port on my camera isn't working... even when it was working it wasn't very reliable. I'm looking for hardware that will allow me to read the DV tape without using the camera and import it to my laptop. Is there anything out there?
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi TheWulf,
    Yes there is - I believe it's known as a "DV deck" or similar. Though I believe they are quite pricey - probably to the extent that it'll be cheaper to get the port fixed, or even buy a new camera.
    Here's an example from a quick search on Google for "DV deck":
    www.abcdv.com/article/articleview/35/1/62/
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. It's much cheaper to buy another camcorder.
    Sep 2001
    Canada
    ouch... damn that sucks. hope i can get mine fixed...
  5. can't you use svideo or composite? at least till you get it fixed.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    not if you only have firewire input
    Read my blog here.
