I have to files one is an avi which is a dubbed audio and the picture is great and the other is an mpeg with good audio but terrible video.
I would like to strip the audio out of the avi and the mpeg and then put the audio from the mpeg onto the avi.
here is the specs on the avi:
video: 607 MB, 828 Kbps, 23.976 fps, 576*240 (2.21:1), XVID = XVID Mpeg-4, Supported
Audio : 89 MB, 122 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
here is the specs on the mpeg:
Video : 1.78 GB, 2622 Kbps, 29.970 fps, 480*480 (1.0:1), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 88 MB, 128 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
please help thanks in advance.
Looks to me like the runtimes aren't the same so you would need to adjust the audio length before remuxing.
Decode the mpg's audio to wav, adjust the length (stretch and/or trim/pad) and then convert to mp3 and remux with the avi.
PotPlayer: no audio switching, no subtitle switching
By WinDVD_5_platinum_fan in forum Software PlayingReplies: 1Last Post: 6th Oct 2012, 21:44 -
Switching to AVCHD
By TheLaserdisc in forum Authoring (Blu-ray)Replies: 18Last Post: 3rd Mar 2012, 23:05 -
LG dvx550 keeps switching off?
By aelfheah in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Feb 2012, 09:43 -
Plz someone help~ switching audio files in VCL player...?
By OokKyou in forum AudioReplies: 3Last Post: 25th Jan 2010, 22:54 -
Switching to Raid 1
By CapeKO in forum ComputerReplies: 7Last Post: 9th Jan 2010, 10:28
