Ave,Originally Posted by reboot
I just made another post actually and then i remembered you were the one who had encouraged me to use ProCoder instead. I successfully setup a conversion from PAL AVI to NTSC MPEG2 DVD using ProCoder, it's going on as we speak. Hopefully everything should turn out OK. I did find the menus and tasks really simple in this software.
Anyhow, i'm facing a different problem and you might be able to help me since you've used this before.
I have a 352 X 288 AVI which i'm converting and i would like to use the NTSC MPEG2 DVD template in ProCoder... however, it's Width & Height are specified as 740 X 480 ..... i want to modify it to the smaller NTSC Compliant res, 352 X 240, but i'm not able to do that. Right-Clicking on the template gives me "Modify" but its greyed out, cannot be used... and so are the Width & Height parameteres in the tab.
Do you know a way to specify 352 X 240 as the output template in ProCoder?
Thanks,
Mickey79
Results 31 to 32 of 32
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it! -
Don't select the DVD template, select mpeg-2.
This should allow you to adjust the output framesize.Cheers, Jim
My DVDLab Guides
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 09:36 -
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 10:58 -
I get 2 layers of subs on video in TMPGEnc DVD Author 3...help!
By tektaktyks in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 12:18 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51
