Ok, so I try to convert a movie that is about 1.3 gig with virtualdub and when i start to convert the file it is way to big. After converting about 6 mins, i figured it would be about 900 meg! What can I do, my video DivX is at 800 kb/sec, what should i put for audio, i dont have the option for divX audio either? someone please help.
900 meg or gig, if it is 900 meg what is the problem?
if it is 900 gig, you need to use some kind of compression, huffuv seems to be the prefered one.
How to convert DV to DivX or XviD using Virtualdub
By Baldrick in forum User guidesReplies: 52Last Post: 1st Dec 2011, 17:04 -
DivX 7 in VirtualDub
By hgd4th in forum Newbie / General discussionsReplies: 5Last Post: 24th Feb 2009, 03:40 -
What exactly is the problem Virtualdub has with Divx multipass?
By Onceler2 in forum Video ConversionReplies: 14Last Post: 20th Aug 2008, 18:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 11:45
