Hi all well here it is.. I have a 500 mb or so avi movie. I would like to burn this avi to cdrw and watch on my sony dvd player which does play vcd. I have a scsi burner that only works on my mac because i have no scsi controllers on my pc. so i want to convert it with my pc using tmpgenc 12a then i want to burn it on my mac with toast. I want to know if this will work or if there is any other way to do this..... short of buying a scsi card for my pc. thanks.
Wizards First Rule: People are stupid. They will believe anything, either because they want it to be true, or they fear it's true.
That will work. That is how I make my VCD's. Actually use the idvd export in iMovie and transfer to my PC encode with TMPGEnc. Then transfer back and burn with Toast 5. I started out using avi files but I just export to the DVD setting in iMovie.
How do you transfer files between your PC and Mac?
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
