I'm using TMPGEnc to make my anime .avi files into MPEG-2 then using DVD-Lab to make the videots folder and burning with Nero. I finally figured out how to get it the way I needed to watch on my TV and all, but for some reason, 1 .avi file will not encode right, but all the others do. When TMPGEnc is done encoding it, the file has no audio and the length of the video is twice as long as it should be. From 0-50% of the video is the whole video and from 51-100% is just blank. Has anyone else had this problem before and could help out? I don't know what's wrong. All the properties of the source file and video all seem to be the same as the files that do work, I've even redownloaded the file but it still won't encode right. Someone help me please? Thanks in advance.
Could be a bad frame in your avi or your avi has mp3 vbr audio which tmpgenc has problems with. Try loading the avi in virtualdub and saving the file as uncompressed wave file. Use the new wave file for your audio in tmpgenc. Also use virtualdub to scan the avi for bad frames.
Good luck!Donadagohvi (Cherokee for "Until we meet again") -
Originally Posted by JRyan2K
When you add the source Video in TMPGEnc, hit the "Edit" button and use Markers to select the actual length of the Video, leaving out the blank portion from the Video. Then encode the select frame-length of your video... you'll get the appropriate results.
MickeyI don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it! -
I have tried doing all of that, but it still doesn't end up right. I used VirtualDubMod to scan the file and it says there are no errors or bad frames. I've saved the .wav and used that with TMPGEnc, but the resulting file's audio is way off from where it should be, like a whole 2 or 3 seconds off. I even tried "editing" where it should encode to and from, and that doesn't work either. I tried bumping the priority of Directshow to the top, and that don't work. I don't know what else to do, the source video plays totally fine on the computer, but when i try to encode it to MPEG-2 with TMPGEnc, it messes it up.
If the audio desync is constant when you use the wav as audio source, it can be fixed in TMPGEnc by applying audio delay. Not uncommon when separating audio from video, and bringing it back together again. Another way is to add some silence/cut a piece at the start of the wav to compensate for the sync problem.
/Mats
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 20:33 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 11:02 -
TMPGEnc won't recognise avi, ConvertXtoDVD no subtitles!
By CaptainChaos in forum Authoring (DVD)Replies: 34Last Post: 26th Apr 2009, 10:59
