    May 2005
    Portugal
    Hey, i'm trying to convert a video in avi format to dvd and normally there would be no problem with it but this is the first time i've tried converting a video that has subtitles interlaced in the avi file. These subtitles are visible with vobsub or ffdshow but the prog i use to convert avi to DVD doesn't recoginze the subtitles. I was wondering if there is any prog that can make this conversion ( avi to DVD WITH the subtitles) or if there is any way of making the subtitles permanent in order to use the prog i use to convert video.
    Thanks.
    thefilmmachine,diko,avi2dvd,dvd2svcd can convert avi to dvd with switchable dvd subs.
    Croatia
    Avi to DVD with permanent subtitles, you should get with Nero Vision Express.
    May 2005
    Portugal
    The problem remains.... Those progs require a subtitle file and i dont have one, the subtitles are IN the avi file but they are not permanent, they are visible using vobsub or ffdshow.
  5. Demultiplex the subtitles to separate file with VirtualDubMod or avimuxgui.
    May 2005
    Portugal
    Thx Abond avimuxgui worked like a charm , i had tried VirtualDubMod but it didn't detect any subtitle stream.
    Dec 2004
    Australia
    VirtualDubMod only supports subs in mkv and ogm.
