I have some Xvid TV episodes with VBR MP3 audio which I have converted to DVD (ac3 audio), yet they are out of sync.
Here is what I did:
For the video...
- Resize with Avisynth
- Encode with TMPGEnc
For the audio...
- Extract to uncompressed WAV with Vdub MPEG-2
- Compress to AC3 with ffmpeg
I then muxed the two together during authoring (using TDA), yet the output is out of sync. Incidentally, it is only like this for some of the episodes I have encoded. Some have turned out OK.
Can anyone help?
If they are out by a constant amount through the length of the video, then you need to add or subtract a delay factor to align them. look in the tools section for ac3 delay corrector.
If they start in sync then drift slowly further and further out, then the framerate of the video has been changed, but the audio hasn't been altered to match. Use something like goldwave to adjust the length of the audio before encoding to AC3Read my blog here.
1) The audio on all the files is 48khz
2) It is always the same amount out of sync
Is there any software which can tell me how much I need to shift the audio stream? Or do I just have to play around with figures?
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio out of sync 5 seconds - DVD ripped with DVD Decrypter + AutoGK :(
By dtel in forum DVD RippingReplies: 20Last Post: 25th Apr 2010, 03:01 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
my dvd is out of sync
By fenics in forum Newbie / General discussionsReplies: 3Last Post: 19th Jun 2009, 08:00
