  1. I recorded a TV show with my Hauppauge WinTV 150 card and when I go to edit it, I've been getting all kinds of weird errors.
    I've tried nanoPEG which came with the card and the end of the video is missing in the editor. When I view the MPEG in PowerDVD the whole thing is there.
    I tried Womble MPEGtoVCR and it only shows the first 5 minutes of the video then jumps to the very end.
    I tried editing another program I recorded and this time I had the middle of the video at the end.
    I'm really pulling my hair out - can anyone help???
    Thank you soooooooo much
  2. I am making my captures with PVR 250 and use Cuttermaran to edit. No probs so far.
    May 2001
    Your nanoPEG software must be junk. Is your MPEG file greater than 2GB and does nanoPEG handle files greater than 2GB? No? I once used a MPEG editor that could only handle 2GB files. I tried to feed it a 4+GB file. The program trashed my MPEG so badly that it had to be re-encoded. I had to write customer service to find out that they couldn't handle a file that large. Go figure...
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  4. As I posted (in that other forum), Hauppauge has updates that fix all this (or should).
    I also posted some other suggestions
    Cuttermaran works best for me too. It's just the extra time involved in demuxing that's annoying.
    Cheers, Jim
    My DVDLab Guides
  5. Well I guess this is a known issue with WinTV 2000 - I'm gonna try GB-PVR.
    Thanks so much for all your input
