When I run ffmpeg using this command:
I get the following failure:Code:"ffmpeg.exe" -i "large.vob" -hq -vcodec mpeg4 -g 300 -b 1450 -aspect 4:3 -s 720x480 -acodec mp3 -ab 448 -ac 2 -mbd 2 -vtag xvid -qmin 2 -async 1 -y "large_1450.avi" -map 0.0:0.0 -map 0.1:0.1
This is an audio related problem, because as soon as I drop the bitrate from 448 to 128, the error goes away.Code:ffmpeg version 0.4.9-pre1, build 4747, Copyright (c) 2000-2004 Fabrice Bellard configuration: --enable-memalign-hack --enable-mingw32 --enable-mp3lame --ena ble-gpl --enable-a52 built on Mar 21 2005 16:41:12, gcc: 3.4.2 (mingw-special) Input #0, mpeg, from 'larg.vob': Duration: 01:02:59.8, start: 0.233567, bitrate: 7586 kb/s Stream #0.0 Id: 1e0: Video: mpeg2video, 720x480, 29.97 fps, 7000 kb/s Stream #0.1 Id: 80: Audio: ac3, 48000 Hz, 5:1, 448 kb/s Output #0, avi, to 'large_1450.avi': Stream #0.0 Id: 0: Video: mpeg4 (hq), 720x480, 29.97 fps, q=2-31, 1450 kb/s Stream #0.1 Id: 1: Audio: mp3, 48000 Hz, stereo, 448 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Error while opening codec for output stream #0.1 - maybe incorrect parameters su ch as bit_rate, rate, width or height
I'm tempted to try that. But doesn't that seperation threaten the synchronization somehow?
I recall someone posting that when capturing video, it's important that the capture device handle both audio and video simultaneously, so it can match video frames to audio frames; and people who use a video-only card and a seperate sound card run into sync issues. One would think that splitting the two streams as you suggest could cause that synchronization information to get lost, resulting in a similar problem. I'm still new to all this type of technology, so please correct me if I'm off.
Isn't there some kind of pairing that could get disturbed if I perform operations on one of the streams in isolation?
BTW- I think the problem that I started this thread about might be that guiffmpeg is forcing me to use mp3, which may not be capable of 448 kbps. Stepping down to 320 kbps enables the encoder to run. So I'm speculating that it's a bug in the gui. -
Actually, I stopped using the audio portion of FFMPEG for encodes because the A/V seemed to end up out of sync ! It is kind of nice not to have to lose any audio quality on your final AVI file by muxing the original .AC3 file back in. DgMpgdec has very good audio and video demux features. The GREAT part of DgMpgDec (which you can run from the command line) is that the demuxed .AC3 file will tell you how many ms out of sync it is, so you can fix it with Ac3DelayCorrector then add it back into your final AVI.
So, it works like this:
Demux the .VOB file to .m2v and .ac3
Run FFMPEG on the .m2v file to turn it into an AVI
Check the demuxed .ac3 file for sync. It will be called something like "my_demuxed_ac3_file-500ms.ac3". That means the A/V sync is off by 500ms. Load it into Ac3DelayCorrector and the app will automatically fix the sync problem. (it's cool how it works). If the demuxed file says "0ms.ac3" at the end of it, no delay correction is necessary, so no need to load it into Ac3DelayCorrector.
Finally, mux the AVI video and the AC3 audio together and Voila ! -
What tool do you use for that? It doesn't seem dgmpegdec can take an avi as input.Originally Posted by Soopafresh
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Analog to Digital Video Converter crapping out
By ScottL in forum Video Streaming DownloadingReplies: 7Last Post: 3rd Sep 2010, 14:01 -
dvd Burner crapping out while burning DL disc, need help
By mazinz in forum DVD RippingReplies: 7Last Post: 21st Jan 2009, 17:38 -
Is my DVD recorder/player or Computer DVD burner crapping out?
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2007, 22:04 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
