I tried searching the forums, but no luck.
My problem: I have a really nice movie with a great message. Want to show it to my kids, but there are way too many profanities, etc.
Is it possible to alter audio track and to replace the unwanted words with let's say "beep" ? I usuall y use DVDShrink and CopyToDVD to backup my DVDs.
What progs would I need for it? I use both Mac (OS X Tiger) and Windows XP machines.
Thanks in advance!
I was told I have a photographic memory...too bad the cap is ON most of the time:(
demultiplex to elemantary streams(audio and video) with dvddecrypter or rejig. edit the audio with for example goldwave. convert to wav, mpa or ac3. reauthor the new audio and the old video with tmpgenc dvd author.
https://www.videohelp.com/forum/viewtopic.php?t=190848
https://www.videohelp.com/forum/viewtopic.php?t=216023
https://www.videohelp.com/forum/viewtopic.php?t=218293
https://www.videohelp.com/forum/viewtopic.php?t=219023
https://www.videohelp.com/forum/viewtopic.php?t=256259
https://www.videohelp.com/forum/viewtopic.php?t=157274
Easiest way probably is to extract the audio by demuxing - VOBEdit can do that. Convert file to WAV (it it isn't already) - besweet or belight can do that. Use something like goldwave to set your in and out points around the cuss words, and replace with a sound of your choice or just simply set the volume down to 0% (so effectively like hitting the mute button). Save out your final WAV, then re-encode to AC3 or MP2 then remux with your M2V file in your authoring tool of choice.
Quickest / Easiest / Fastest way IMO is to not let them watch it at all if you don't want them to hear the words - they're gonna hear 'em sooner or laterIf in doubt, Google it. -
thanks, guys, for the tips. I'll try those.
Quickest / Easiest / Fastest way IMO is to not let them watch it at all if you don't want them to hear the words - they're gonna hear 'em sooner or later[/quote]
I know they willI just don't want to "help" in that process....(but that's for another forum
I was told I have a photographic memory...too bad the cap is ON most of the time:( -
http://www.cleanfilms.com/ They rent and sell movies that have already been edited for family viewing.
Insert "beep" audio to black out words in a mp4 file
By IngvarEkstrom in forum Newbie / General discussionsReplies: 18Last Post: 30th Dec 2020, 13:24 -
Motherboard "BEEP" Has Replaced Windows Sound
By hech54 in forum ComputerReplies: 17Last Post: 2nd Jan 2011, 14:09 -
Is IMdb using curse words in titles now ?
By vhelp in forum Off topicReplies: 5Last Post: 26th Oct 2009, 16:18 -
Easiest way to edit Curse words
By glenn71x in forum EditingReplies: 37Last Post: 15th May 2008, 09:31 -
Seeking help on "bleeping-out" bad words
By dough in forum Newbie / General discussionsReplies: 20Last Post: 26th Sep 2007, 15:50
