I just bought my 1st dvd burner and I am wondering about his popup that came up in DVD Decrypter.
What does this mean. I live in Canada and I didn't know I had to set the region code for my DVD burner in DVD Decrypter. I know this is dumb but would it matter if I set a region or not. Also I don't see Region 0 anywhere. Any reasons why?
allyourbasearebelongtous
most DVD rom, burners and players have set region codes and will check the DVD that you are trying to play/rip has the same region code. So a region 1 player will play region 1 DVDs but not region 2 or 4. Region 0 means that is region free which means it doesn't matter. There are region free DVDs and players., as for rom/burners you can go to the following site to update your firmware on you DVD Rom/burner to make region free.
http://forum.rpc1.org/portal.php
hope this helps -
So then I should set my dvd burner to whatever country/region I am in so this doesn't pop up everytime?
allyourbasearebelongtous -
Originally Posted by werty316There are 10 kinds of people in this world. Those that understand binary...
Being able to set region code in LG BD550 blu ray player
By bevivek in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2011, 06:11 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12 -
DVDDecrypter wants to set Region Code
By src2206 in forum DVD RippingReplies: 6Last Post: 15th Feb 2009, 11:38 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 17:08
