Ok here what I did.
I use virtualDub, the setting are:
Audio: Full procress Mode
Conversion-44000 Hz High Quality
Compression: None
Video: Direct stream copy
then I use TMPGEnc Plus to convert to MPG
MPEG-2 video
480x480
4:3 Display
29.97 fps
CBR
2000 kbits/sec
NTSC
Noneinterlace
Advance:
4:3 525 line (NTSC, 704x480)
Full screen
When I done converting. I use DVDPatcherv1.6 to conver the header of svcd. After I have finished I use DVDAuthor to add the .mpg file but I have an error it said "The video sequence header is incorrect A"
Then I use MPEG2Cut2 to Save as .mpg again because I have done this before with the other movies and it correct the Sequence header for me. Unfortunately, this time it doesnt work for me. Anybody know what my problem is.
why not convert to dvd? use 352x480 if you want to use a low resolution.
Sounds like the program's detecting a mismatch twixt your audio sample rate and the type of video. Baldrick's suggestion is the way to go. Probably your audio's at 48 khz and for some reason it's not being sample-rate-converted. If so, 352 x 480 will solve your problems.
Avi files missing header?
By hockeygt975 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2014, 03:18 -
AVI broken header file
By magillagorilla in forum RestorationReplies: 3Last Post: 23rd Sep 2011, 09:01 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
header information of MPEG-4 and AVI
By firadayat in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2009, 08:53 -
How to fix/repair a AVI video without a header?
By BlooderButcher in forum RestorationReplies: 4Last Post: 2nd Dec 2007, 10:42
