Is there any software out there that will do on-the-fly transcoding of AVI files (mostly xvid) and serve them as ReplayTV compatible MPEG streams, so I don't need to plan ahead and use extra disk space?
(Or if not, is there anything that will at least go from AVI to ReplayTV compatible/DVArchive importable MPEG in 1 step?)
Looks like the Mpeg2 created by replay is "almost" standard fare. You ought to be able to do it with the command line app FFMPEG, in order to encode your AVIs into Mpeg.
However, look on this sight. It might be more applicable to your situation.
http://www.planetreplay.com/phpBB2/index.php
Choppy .avi playback to Xbox 360... only with .avi and only when streaming
By smitbret in forum Media Center PC / MediaCentersReplies: 12Last Post: 29th Mar 2011, 08:53 -
Converting streaming MPEG-2 to H264
By tripflex in forum Video ConversionReplies: 6Last Post: 13th Apr 2010, 14:01 -
MPEG clips truncated when streaming
By njaounteisc in forum Video Streaming DownloadingReplies: 1Last Post: 20th Mar 2010, 08:07 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 08:19 -
Tsunami-Mpeg DVD Author Pro Transcoder Question
By RKelly in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 22:51
