I tried with TMPG encoder and the file estimate around 3gb. So can anyone help me? (I want at least 500mb, enough to watch).
Best MOTORing fans
vcd is pretty standard.. 10mb a minute.. so unless the avi was around 5 hours long, you did soemthing wrong.
ur Avi file is 3gb? and ur trying to convert to mpeg1? so what happened when u tried doing so with tmpgenc. where did the process go wrong exactly...clarify please. did tmpgenc not allow u to complete or u meant the result was a 3gb mpeg file, coz that cant be as lumas already said.
VERVEGod Bless Lebanon... -
This wont fit on a CDR as VCD, although you may be able to squeeze this onto a 99min CDR as a SxVCD.Originally Posted by Ryosuke_Gunma
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Could be the AVI has VBR audio? This throws TMPGEnc off completely. Solution? Extract audio to wav first, select wav as audio source, AVI as video source when encoding. But still, 80 min is what you can fit on a regular CD as VCD.
/Mats
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
I can't play a big avi file
By Xp4nd3r in forum Newbie / General discussionsReplies: 6Last Post: 20th Feb 2009, 07:29 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
.AVI file too big for utube - how do I get there?
By jaug in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 19:58
