Is there any VM command (which I then would use with PCGedit) which presets the button to be selected when entering a VTS Root menu? In other words, I would like that when the Root menu is entered, button number x is pre-selected, so that I just need to press Enter in the Remote control to select button number x. Does a similar command exist?
It might be useful when e.g. you have sequential clips and, once you have seen clip number x-1 and you return to the menu, you have already button number x pre-selected.
There is a VM command... But I don't know it (for PCGedit).
You can create a little project with my GUI for dvdauthor (use no Titlesets), and examine the result with PCGedit. GfD uses a precommand for the vmgm menu where the selected button is set to the last used button.
In dvdauthor language there is a command:
button=X
where X is the button number of the pgc multiplied by 1024GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Handbrake Preset Confusion
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2011, 00:38 -
What preset should I use in premiere for 60i?
By theguy1991 in forum EditingReplies: 20Last Post: 8th Jun 2010, 13:18 -
Does anyone have a MASTERING Preset for tmpgenc plus?
By underp in forum Video ConversionReplies: 0Last Post: 31st Mar 2009, 11:26 -
sony vegas only has 2 preset resolutions
By auto7890 in forum EditingReplies: 1Last Post: 6th Oct 2008, 19:27 -
PS3 Preset Anyone?
By croops in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2007, 19:12
