I borrowed a couple of burned DVD's from my friend and when I tried to rip them to my hard drive, I got and cylic redundency error. The discs are spotless and I tried DVDShrink, DVD Decrypter, and Nero 6. I have a Toshiba burner and my friend has a new Sony DL burner. His burns at 16x and mine only burns at 2.4x. I thought that speed would have something to do with it so I told him to burn a movie at 4x and he got Burn Attempt Failed message or something like that when he used Nero 6. He also used DVDShrink to rip the DVD. What could be the problem?
Try use the scandisc in nero cd dvd speed and see if you can read the entire media. The media could be crappy and it doesn't work on some dvds.
Are you sure that your friend Finalized the disks? Failing to Finalize a DVD allows very few if any other DVD drives the ablility to read them.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
if the errors are of CRC type they are most likely not because of unfinalized disks. Your friend should use higher quality media or some media that works better in his drive. Tell him to visit www.videohelp.com/dvdmedia
All right thanks for all of the feedback. I didn't try different media but when I used my old DVD-ROM drive, it could rip most of the DVD's, but not all of them This pretty much convinces me that it is his media.
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 16:46 -
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 14:57 -
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 14:22 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 16:51 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 02:23
