hi
my ulead dvd workshop2 offers me to use mpeg2 compression, using either mpeg audio (mp3 I guess) or PCM audio.
is PCM in dvd is better than the compressed audio?
what are the size differences?
thanks
[/quote]
MPEG audio is either MPA (MPEG1 Layer II) or MPEG2 audio. Both are compressed. MP3 is not supported by DVD.
PCM is NOT compressed, so technically it is "better". However, it is also about 7 times the size of a compressed file.
But the human ear usually cannot tell the difference between PCM and compressed audio.
I recommend that you use the MPEG audio (but check your player to see if it is supported).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
parse ts pcm stream
By niror in forum AudioReplies: 2Last Post: 2nd Oct 2011, 02:36 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
iv50 pcm?
By dinofava in forum Video ConversionReplies: 9Last Post: 11th Oct 2009, 10:33 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 11:53
