Hi, don't know if this is the right forum but, does anyone know if there is any free software that I can get to send MPEG's to DV video? Like if I hooked up a DV camera to PC with firewire and just record the MPEG file from the computer to the DV tape. I was told this can't be done on Windows Movie Maker, which seems stramge since iMovie for Mac can. And it seems to be a basic function. Can anyone help me out?
I would suggest first encoding the mpeg to DV avi. You can do this with virtualdubMod. Then you can send this to the DV cam with DVIO or WINDV, both free.
There are 10 kinds of people in this world. Those that understand binary... -
The help file for Movie Maker 2 says that you can export your movie back to a DV camera via firewire. Note that it won't convert the sound in a mpg file if its ac3.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
