I have 3 dvd's that i would like to back up on to 1 dvd. Now i've exracted all the files from all the dvd's to my hard drive using dvd shrink then used dvd shrink again to edit them and bring down the total size of all 3 dvd's so that it can fit on to a 4.7 gig dvd. eveything seems to be working fine like it should be i get my audio_ts and video_ts folders with all the files in. Now i tried to add these files in to TMPGEnc dvd author and creat a new project but at the end i get the following error.
The combined bitrate of the clip exceeds the upper limit for a standard DVD.
The combined bitrate of the video and audio of clip "xxxx" of track "xxxx" is exceeding the upper limit for a standard DVD.
The current bitrate is 9800 kbps for video, 384 kbps for audio, and 10184 kbps combined.
It is necessary with a combined bitrate of less than 9.848Mbps (9848kbps).
Any help would be great guys.
Thanks Again
Shouldn't have DVD Shrink have reduced the size of your videos? I think that you mean that the BR in your header is 9.8Mbps (unless you've done something terribly wrong).
Run your videos through BitRate Viewer and record the MAX BR, then use RESTREAM to change the header to that value.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 1st Nov 2011, 00:11 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 15:43 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 19:18 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 15:15 -
burning problem with backing up my dvd's
By sscottsa315 in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2009, 21:36
