ist there a way to check if there were any probs burning without watching the whole thing
i use the scandisk in nero cd dvd speed
read http://www.digitalfaq.com/media/dvdmedia.htm -
how much percent damaged or unreadable would the disc be before being a coaster, i got 99.46% good, 0% damaged .54 unreadable
Any less than 100% = coaster.
But remember, some of this depends on the quality of the drive being used to test.Want my help? Ask here! (not via PM!)
I use Ahead (Nero) CD/DVD Speed for the first pass. If I get a nice smooth curve, all it well. If I get any deviation, then I use DVD Info Pro to read test.
Read my blog here.
I normailly get a smooth curve but accassional tiny downward spikes. Nothing that will cause me to redraw the curve. That tells me at least it can be read without any retries which I assume would create bigger spikes in the curve. If I want to go further I den to a data and surface scan. I get all green squares so I assume my picky DVD player will be happy with it.I use Ahead (Nero) CD/DVD Speed for the first passNo DVD can withstand the power of DVDShrink along with AnyDVD!
Toshiba SD-290 - Not Reading Burnt Discs (I've read the sticky)
By irish-sid in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Feb 2011, 10:06 -
Error Checking CD's
By Nitro89 in forum AudioReplies: 30Last Post: 9th Nov 2009, 00:58 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Nero 8 Stuck at checking discs
By Brainiac in forum ComputerReplies: 9Last Post: 11th Jan 2008, 12:28
