I have a video clip that is NTSC 4:3 (720x480), but the actual video is only in the middle portion of the frame - the rest (top and bottom) is black. when i convert the file to DVD, and play on my widescreen tv, it looks about the same - black on top and bottom. My question is: I used Mainconcept Encoder to convert to MPEG2, used the crop function to crop off the top and bottom portion (leaving only what I want), specified it as 16:9, and then authored with TMPGENC Author. Now the video fills my widescreen tv (nice), but it looks like it's been stretched vertically - something is wrong. What have I done wrong? Is there a proper (easy) way to do this? thanks.
Results 1 to 12 of 12
It could be a 2.35:1 video and then should you leave some black borders.
And why not use the widescreen tv zoom? you are zooming when you are encoding and cropping and upresizing to dvd with mainconcept. -
my tv won't zoom from the component inputs - only on cable.Originally Posted by Baldrick
No, your question is not dumb. It seems I gave you dumb advice
If you want to make 4:3 NTSC to 16:9 NTSC simply crop 60 pixels from the top and 60 pixels from the bottom. Then encode as 16:9. I think it should work.
If the black top and bottom is more than 60 you leave the remain intact otherwise you can get distorted aspect ratio. -
cool. now i just have to check if Mainconcept will allow me to crop a specific number of pixels from the top and bottom. think it does. thanks.Originally Posted by Abond
After cropping 60 pixels vertically wouldn't he have to stretch it vertically by 4/3 to get back to a 720X480 frame and maintain the correct aspect ratio? I'm working on a similar problem myself.Originally Posted by Abond
Your DVD player will probably do the zoom at the expense of the left and right sides..Originally Posted by revlis
Hi-
If I'm understanding him correctly, it's a 4:3 widescreen DVD, so it displays with pillar bars on the right and left sides, as well as very large black bars on top and bottom, when played on his widescreen TV. However, I find it bizarre that neither his TV set nor his DVD player has any kind of a zoom feature to fill the screen left to right, keeping the AR.
The unsaid but obvious next step would be to resize to 720x480 before encoding as 16:9.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Widescreen shows up on the PC but as fullscreen on the TV?
By Moontrash in forum Authoring (DVD)Replies: 8Last Post: 17th May 2010, 18:26 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 15:54 -
Merge fullscreen and widescreen
By jin007 in forum Newbie / General discussionsReplies: 8Last Post: 25th Jul 2008, 09:06 -
Widescreen To Fullscreen
By OG24 in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2007, 16:51
