I am trying to use this program to edit VOB files. What I do is extract the VOBs from an ISO file using ISObuster. The ISOs in the DVDs and hard drive come from web downloads. I get the following files:
video_ts.bup
video_ts.ifo
video_ts.vob
vts_01_0.bup
vts_01_0.ifo
vts_01_1.vob
vts_01_2.vob
vts_01_3.vob
vts_01_4.vob
vts_01_5.vob
The problem is that some files load and other do not. In the example above, vts_01_1.vob loads and is editable. However, vts_01_2.vob does not load and gives me the following error message:
This is an illegal video file.
For DVD standard you can only use
MPEG-1 video or MPEG-2 video
What is more the ISObuster option to extract the MPEG files is not available, I can only extract or run the Vobs. Some of the other files, vts_01_3.vob also load and usually the last VOB file also loads. However, if there are only two VOB files, the last one does not load.
Any ideas of what is going on. Or better yet, does anyone know of a different program that edits VOB files.
Thank you.
cai
Try select add dvd-video in tmpgenc dvd author and choose the folder with the vobs instead of open the vobs one by one.
Baldrick:
Thank you for your suggestion. I tried it last night and it worked with an ISO file that I had completely extracted. I thought that option was to be used only when accessing DVD disks. Thank you for the clarification.cai
DVD Flick Error Message
By Dee826 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:08 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
Error message with DVD Santa
By poppy56 in forum Newbie / General discussionsReplies: 8Last Post: 1st Feb 2008, 18:00 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
