I tried following the method suggested at vcdhelp.com using VirtualDub. I follow all the instructions, and when I goto save it gives me a message saying how I'm using a hacked codec, and whether I'm sure I want to continue ( it says it might crash, or something like that). I click okay, and VirtualDub doesn't show any progress, and when I stop it I always end up with a 16 meg file. Has anyone had the same problem and know what to do?
I should also mention that I have both DIVX 3 and 4 installed.
Hi
It is normal to get that warning, "We" all ignore it
However there should not be a problem in saving the file.
Do you only get this problem with that codec ?
I use DivX fast motion, Mpeg 4 V2,3,4 etc with no problems.
according to the instructions here on vcdhelp it says to use the Low Motion codec (DIVX 3), so thats what I've been trying it with.
What's the difference between the two codecs?
Maybe I'll try it with DIVX 4, but I'm not sure which settings I need. -
Hi
Gosh you read the instructions ?
My moto is try it and see, Try them all !! what is best for you might not be best for anyone else, depending on the quality of the source.
Try a few out and you decide which is best
Converting Divx to AVI with a Twist
By Deathbot70 in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 13:42 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 14:07 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 15:17 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 13:56
