Using Vdub to encode MPEG2 to XviD avi's, There are 2 XviDs shown in my compression list. one is xvid.dll and 'yxsomethingsomething'.dll . Doesn't matter which one I choose, when I start encoding, there's an error message saying 'stats file cannot be found or something like that' and 'operation cannot be done' or something along those lines. I checked, I DO have Xvid codec installed (should be correct).
Help anyone?
Thx.
Forgive the Noob
XviD.dll is devapi3. What you should have is XviDVfW.dll.
About the error though. Sounds like you are doing a 2nd pass without running a 1st pass to create the stats file. -
ok, how do i solve the 1st prob then.
And oh yeah, what's with this 1st pass, 2nd pass thing? what's it for?Forgive the Noob -
ok went to check, it seems the difference between the two xvid options i have is the FOURCC code. One being 'xvid' the other being 'yv12'. What's that?
And I see the option of like simple, simple L0something, and many others similar to that. What are those? And of course the 1st pass thingy.Forgive the Noob -
YV12 is there to make sure that XviD handles YV12 decoding, for say loading AVISynth scripts. Personally I used the Helix YV12 codec.
The deal is, you run the 1st pass, then the 2nd.
Those are different MPEG4 profiles. Don't remember devapi3 having profiles though. You sure it doesn't say xvidvfw.dll? -
sorry 'bout that, yeah the driver is 'xvidvfw.dll'
so which one do i choose for compression? 'yv12' or the regular 'xvid' fourcc code? oh and which mpeg4 profiles do i use? i'm encoding to avi, y do i need mpeg4?Forgive the Noob -
Shouldn't matter. I would use the XVID one though, mainly because I have a different codec installed to handle YV12.
Unrestricted, unless you need VBV, etc.
XviD is an ASP MPEG-4 video codec. If you don't want/need MPEG4, don't use XviD.
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 02:48 -
Help with MKV to XviD Conversion
By Chaser250 in forum Video ConversionReplies: 9Last Post: 20th Feb 2011, 03:08 -
DivX/Xvid conversion
By joecass in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 15:23 -
AVI to Xvid conversion
By Davjefdunn in forum MacReplies: 4Last Post: 16th Sep 2009, 09:48 -
Help with conversion to Xvid
By zovx in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 15:32
