I was wondering does anyone here know to use vb6. My problem is I am setting up a menu for a disk of software (freeware), now the problem is I want to set-up buttons. So when the end user click on the butttons it installs the software,rather than going though the disk and it makes it look more up market. any ideas?
many thnxs
u mite be having some probs in autorun menu just try 2 connect the root of setup 2 the autorun menu
[Release] Philips 5990/12 modded firmware by vb6
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 140Last Post: 28th Sep 2015, 03:06 -
AVStoDVD does not start... says "VB6 Common Controls not found!"
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2011, 08:15 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 21:00 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 20:37 -
how to use ffmpeg in vb6 ?
By mehdi0016 in forum ProgrammingReplies: 0Last Post: 23rd Dec 2007, 12:44
