Results 1 to 9 of 9
  1. I have 1 wmv file now and it has 30frame/s !
    The problem is i want to convert it to VCD , but my sound is ouf of sync because NTSC-VCD only support 29.997 F/s
    I searching around but still cant find a solution for my problem
    Help me please ;_(
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Re-encode it with TMPGENC. Should come out fine.
  3. More detail please ?
    I know how to reencode with Tmp, but, which option i must chose to convert 30f/s to 29.997 for example ?
  4. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Choose the NTSC VCD option.
  5. Yep, already done it, but i still have the out of sync problem , because like i said above, main problem is my wmv file has 30frame/s , but VCD-NTSC in Tmp only support 29.997 f/s !
    Any better way ?
  6. Is there any way to convert wma with 30frame / second to NTSC or PAL system ?
    PLease help me ? or Just tell me, can or cant ?
    canada
    Tmpgenc will properly encode 30fps to 29.97 fps without audio sync problems as long as there is nothing wrong with the source file.You will have to fix the audio yourself by either stretching or shrinking it if the audio is losing or gaining sync or adjust it to match if just off by a bit.
    If this is too much work for you then nuke the wmv file.
  8. Thanks but is it any another easy way ? or soft ? Because i have alots of Wmv files to do
